Results 1 to 10 of 20
Thread: Groaning/Squeaking Suspension
    Mar 2008
    Canning Vale, WA
    Hey Everyone,
    I recently had the Eibach Pro Kit fitted to my GTI, and Ive just started noticing that the front left suspension groans/squeaks when travelling slow.. mainly when pitching (accel from a red light for instance) or turning at low speed (say reversing off the drive way).
    It has been raining alot.. dunno if that contributes to it (perhaps the stupidest thing i could say? haha)
    Just wonderding if anyone has a quick diagnosis for the situation?
    I got the springs installed at a reputable suspension place here in Perth also.
    Im coming up to 22,500kms, and am going to have my wheels rotated and oil changed... and was going to bring the issue up, but thought perhaps I should ask here so i have some knowledge first....
    Thanks in advance peoples.
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
    Dec 2006
    T_go have you upgraded the front sway bar and or larger dump pipe? The reason I ask is I have the same noise and JMac is pretty certain its the front swaybar bushes drying out due to heat from the dump pipe. That being larger dump pipe and thick sway bar = the 2 parts alot closer cause easier heat transfer.
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
    Mar 2008
    Canning Vale, WA
    Nope... no other changes down there....
    T Go
    Feb 2008
    This is your front sway bar links groaning under the increased pressure of the lowered car suspention. When I loweredmy car on my Weitec springs, I cot the same problem. You can replace them with adjustable sway bar links, or you can buy Frod Mondeo(95-2000 model I believe) links on Ebay.
    Mar 2008
    NSW
    I also got this groan when crawling after I got H&R springs installed. Its not so bad now, been couple months.
    Essendon
    I've got this too and I'm stock!!
    Sunroof // ICT Tint // Seats // Steering wheel
    Jan 2009
    blankedy
    Is it definitely coming from your suspension?
    I had a noise I assumed was in the dash / door, fixed by VW but apparantly was the radiator mounts...
    Melb, Vic
    i too get this noise mainly when im near full lock turning
    APRV2:H&R SPRINGS:SEAT INTAKE:CUPRA R BUSHES: FORGE STRUT BRACE
    Nov 2008
    Wembley, WA
    I had this issue after installing my Bilstein/H&R combo and it turned out to be that the top mount bolts had loosend a fraction. I had to have them retightened twice in the end. I had Pedders Morley intall mine and I couldn't recommend them enough.
    Dec 2008
    South Africa
    Ive had this issues recently, when driving slow there is like a squeak sound coming from m front tyre.. Turned out it was the backing plate for the brake pad that somehow got a bit offset and was touching against rotor/disk
    Didn’t damage anything but the weird thing is that I changed pads a few months ago, and problem only arose in past few weeks
