I've changed the gearbox oil yesterday with Redline MTL. Used 2 bottles + a bit from a 3rd bottle (each bottle had 1 US quart ~ 0.95 liters).
how much oil does the gearbox take and is there a filter to replace too?
i have read a few times in this fourm that redline is the brand to get. anyone have good experience with other oils?
06 Polo GTI
standard ECU, wheels | K&N Panel filter | PD160 intake tube and trumpet |Nulon 5W-30 | Michelin contact sport 3
No gearbox filter, the capacity is 2L which is unfortunately a tiny bit less than two bottles of Redline. It's nice and easy to do yourself, the only hard part is tracking down a 17mm hex socket to take the sump plugs off.
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
thanks all!
a 17mm hex socket should be no problem....if i dont already have it, my neighbour does
06 Polo GTI
Just did this bolt and nut trick with weld on my Polo - worked a treat. I couldn't get the tool locally either. However mine only took just less than 2 bottles of Redline. Even tried taking the weight of the front with a jack to increase the height of the filler, but oil was still coming out the filler. Can only think that maybe it didn't drain fully. The amount of oil that came out was definitely less than what I put back in, so I feel happy enough.
I have a 17mm allen socket if your neighbour doesn't. I can also sort out that pesky standard ECU you have too.
thanks for the help folks.
gavin, thanks for the offer of fixing the pesky standard cpu but i'll be keeping her standard for the time being. Any $$$ i have to spend on car mods are getting built up to spend on my torana which is about to score a new motor im building, repaint, etc etc etc.
06 Polo GTI
