Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: gearbox oil change
    Aug 2009
    gearbox oil change
    how much oil does the gearbox take and is there a filter to replace too?
    i have read a few times in this fourm that redline is the brand to get. anyone have good experience with other oils?
    06 Polo GTI
    standard ECU, wheels | K&N Panel filter | PD160 intake tube and trumpet |Nulon 5W-30 | Michelin contact sport 3
    Jan 2009
    Bucharest, Romania
    I've changed the gearbox oil yesterday with Redline MTL. Used 2 bottles + a bit from a 3rd bottle (each bottle had 1 US quart ~ 0.95 liters).
    Guest0608 Guest
    Quote Originally Posted by blackbetty View Post
    No filter required/ none fitted to manual box..............vwtech
    Aug 2009
    No gearbox filter, the capacity is 2L which is unfortunately a tiny bit less than two bottles of Redline. It's nice and easy to do yourself, the only hard part is tracking down a 17mm hex socket to take the sump plugs off.
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Aug 2009
    thanks all!
    a 17mm hex socket should be no problem....if i dont already have it, my neighbour does
    06 Polo GTI
    Sep 2006
    Quote Originally Posted by break View Post
    Hmm Ebay
    Just got one off Ebay 10 min ago, to add to my tool collection
    Was only about $15 from UK
    Adelaide hills, SA
    You could use two M10 nuts with 17mm hex screwed on M10 bolt, Loctite them or weld them to form longer hex, insert it in 17mm ring spanner or socket.
    Nov 2008
    Just did this bolt and nut trick with weld on my Polo - worked a treat. I couldn't get the tool locally either. However mine only took just less than 2 bottles of Redline. Even tried taking the weight of the front with a jack to increase the height of the filler, but oil was still coming out the filler. Can only think that maybe it didn't drain fully. The amount of oil that came out was definitely less than what I put back in, so I feel happy enough.
    I have a 17mm allen socket if your neighbour doesn't. I can also sort out that pesky standard ECU you have too.
    Aug 2009
    thanks for the help folks.
    gavin, thanks for the offer of fixing the pesky standard cpu but i'll be keeping her standard for the time being. Any $$$ i have to spend on car mods are getting built up to spend on my torana which is about to score a new motor im building, repaint, etc etc etc.
    06 Polo GTI
