Results 11 to 20 of 21
Thread: gearbox oil change
    Gosford Central Coast NSW
    for anyone interested - I have found that the best 17mm socket tool can be made by grinding the rounded base off of a standard VW wheel bolt, and cut off the thread. The hex section is just the right length to go the full depth of a 1/2" 17mm socket and hte full depth of the plug.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    NSW
    Where do you guys buy Redline MTL from?
    Jan 2009
    blankedy
    There is an ebay store or I think performance lub (google it) sells it as well. Actually, I think its the same guy...
    Jul 2010
    Autobarn in Auburn sells it. Thats where i got mine.
    MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
    Aug 2007
    I sell it!!!
    Alba European
    Aug 2009
    Quote Originally Posted by Jmac View Post
    I sell it!!!
    I bought mine from Jim.
    Good to see I wasn't the only one stuck in the traffic mess this morning ey Jim
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Croatia
    Hi everyone
    i would like to change my gearbox oil on
    polo 1.9 SDI 2006. manual ofc
    does someone have some instructions or pics where are the drain and fill screws?
    how to make sure all of the old oil drains?
    is there any magnet that collects the remains from the gear wear, if so is it possible to clean that without taking the gearbox down?
    some pics of gearbox if it helps
    nsw
    Do you need to replace the gaskets on the sump plugs or do the original ones seal up fine again?
    sam
    Adelaide hills, SA
    Always replace the washer on the drain plug, it's just a cheap insurance to eliminate the oil leak from the d.plug.
    Croatia
    doesnt anyone know how to replace gear oil in my gearbox (02T)
