Results 21 to 30 of 31
Thread: Gearbox crack
  1. #21
    Jan 2014
    Clontarf, Queensland
    Thanks Sean - I'm thinking stage 2 but also looking at the VR6 option as a contender. Depends on cost/availability as I can't keep the car off the road for weeks.
    02S box looks to be the one - just going to do some ratio comparisons to check it all looks good. Hoping to pick one up that doesn't need too much work ie. reconditioning. Planning stage 3 eventually so wouldn't mind doing it right.
    Anyhow if this looks promising I'll start another thread on the install.
    Mods >1
  2. #22
    Jan 2014
    Quote Originally Posted by GRP View Post
    Have you found out the cause - cracked casing due to god knows what or casing cracked by internal failure?
    Curious to know myself! Will report back in a week or so.
    Mods >1
  3. #23
    Jan 2014
    Finally removed the gearbox today with help from Gav and found the problem.
    The diff has punched a hole through the gearbox. Gearbox crack probably by one of the diff bolts. So at least the problem has been found.
    Next step is getting the six speed to fit Gearbox crack
    Mods >1
  4. #24
    Oct 2015
    i would love a write up and pics on this. would b an awesome upgrade!!!!!
  5. #25
    Does the 6-speed require some preventative work to avoid this happening a second time, or are they different altogether?
    Cheap, Fast, Reliable. Choose two.
  6. #26
    Dec 2008
    Sydney/Canberra
    Is this the same 6-speed that drops the roll pin out of one of the selector forks?
  7. #27
    May 2011
    Albury, NSW
    Unsure if it's compatible but I have an 02M (6 Speed) Shifter and cables lying around if you need them.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
  8. #28
    Quote Originally Posted by Umai Naa!! View Post
    Not seen that mate, more details?
  9. #29
    Jan 2014
    Will start a separate write-up soon on the install. There's quite a few examples getting around in the UK using the 02S box.
    The bell housing is effectively the same so its bolts on. There's a few minor mods to make it all fit.
    As for the longevity of the box - it's built to much the same standard as the Polos 02R box so I'd be guessing they are similar. The good thing is there's plenty of them around so if this one breaks I'll find another one.
    Reconditioning is about 1200 but I don't think it's worth it at this stage. I might look to do the diff if this works out.
    Mods >1
  10. #30
    Jan 2014
    Gearbox crack
    As Gav mentioned I'm not sure I've heard of this.
    The selector forks are coming off the 02R box so I don't think it's an issue for me.
    Mods >1
