Welcome Chris, good to see you have joined up over here. Hows your rebuild going??? whats the ETA of you having it back......
BTW have a look at this thread may be of some help. ECS Clutch Thread
agreed, i just wanted to know if they fit as i dont wanna buy stuff then be stuck with useless parts that dont! will this kit fit then
its the mk4 golf git
another option i can happily advise on is the following setup.
is a 12lb Eurospec Flywheel + vr6 clutch kit but do get genuine throw out bearing.
No mods required to get these clutch kits installed.
However you will find the clutch to be a little stiff for the first 500 - 800kms while it's bedding in, drive lightly for around 350kms and slow increase to spirited driving. Once bedded. The clutch combo is super super light has approx 450 - 500nm clamping force. So no slipping will occur.
And is simply the best setup i have driven in a 1.8t.
I have driven 23 Golf gti's with all different kind of clutch kits.
Audi S4 (2001) - Imola Yellow
Secret Project
awsome , let us know how you go with it.
Clutch feels good, its only early days I guess it has to "work in"
I def feel more acceleration not heaps but noticeable (altough I have Forge TIP and APR R1 Diverter Valve installed at the same time).
It feels similar to OEM but is quite noisy but that does not worry me. All in all a good purchase.
