steering colomn bearing look for little ball bearings on the carpet happened on my car also look for new found play in colomn
my Polo developed a funny steering sound on the last cruise on sunday.
whenever i turn my wheel it sounds like sandpaped rubbing slowly against metal..
any ideas as to what the problem may be? any help would be fantastic!
playing or thrashing???
does it still do that clicking thing?
u could try some lube spray from underneith where the bearing is or from the top but u have to remove steering wheel airbag if it has one but make sure you mark the steering wheel before removing so you get the same exact spot or will be offcentre
Check the horn contact (metal tang) that rubs against steering wheel/slip ring.
Just use two small screw drivers to release the tension just enough so not to loose contact with tang. Could also try to lube with light grease.
Jaimo.
06 Jetta/09 Pirelli/DSG
08 T5 BPC/Auto
08 Caddy Maxi life TDI/DSG
12 Up!.
ahh forgot about that yeh does make scraping noise metal to metal problem solved i think
Mine makes gurgling cat noises every now and then.
I'm just going to leave it until it breaks so I won't get told there is nothing wrong with it.
