Check the horn contact (metal tang) that rubs against steering wheel/slip ring.
Just use two small screw drivers to release the tension just enough so not to loose contact with tang. Could also try to lube with light grease.
Jaimo.
champion ill give that a crack and get back to you!
VW: it aint just a car, its a way of life There are few things more satisfying in life than finding a solution to a problem and implementing it
