Results 1 to 10 of 10
Thread: funny steering wheel noises
    my Polo developed a funny steering sound on the last cruise on sunday.
    whenever i turn my wheel it sounds like sandpaped rubbing slowly against metal..
    any ideas as to what the problem may be? any help would be fantastic!
    Oct 2006
    sydney
    steering colomn bearing look for little ball bearings on the carpet happened on my car also look for new found play in colomn
    Been playing with it too much i'd say
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Jun 2007
    Eastern Suburbs Melbourne
    playing or thrashing???
    does it still do that clicking thing?
    i like volkswagens
    Quote Originally Posted by william View Post
    theres no extra play in the steering column it is as normal and there are no bearings on the floor
    any other ideas? does it need a lube up?
    Oct 2006
    sydney
    u could try some lube spray from underneith where the bearing is or from the top but u have to remove steering wheel airbag if it has one but make sure you mark the steering wheel before removing so you get the same exact spot or will be offcentre
    Apr 2006
    Nth of Nowra.
    Noise
    Check the horn contact (metal tang) that rubs against steering wheel/slip ring.
    Just use two small screw drivers to release the tension just enough so not to loose contact with tang. Could also try to lube with light grease.
    Jaimo.
    06 Jetta/09 Pirelli/DSG
    08 T5 BPC/Auto
    08 Caddy Maxi life TDI/DSG
    12 Up!.
    Oct 2006
    sydney
    ahh forgot about that yeh does make scraping noise metal to metal problem solved i think
    Alfred Cove, WA
    Mine makes gurgling cat noises every now and then.
    I'm just going to leave it until it breaks so I won't get told there is nothing wrong with it.
    Quote Originally Posted by jaimo View Post
    Jaimo.
    champion ill give that a crack and get back to you!
