The basic problem is that the car is hugely unbalanced with all the stuff removed from the rear and the aero package needed to fix it would be dramatic and probably impractical for street use.
I'd try putting the rear seat back in and filling the tank up to see how it feels but without doing proper timed track sessions, you will never really know which setup is faster unless you can get accurate splits for that sector with a timing device.
Resident grumpy old fart
