Results 1 to 6 of 6
Thread: Fuel Injectors Flow Rate
    Jan 2008
    Does anyone know the flow rate (in cc) of the GTI injectors?
    Would upgrading to the K04 require a new fuel regulator and larger injectors? Or will that only be requiered if your going to a GT28 turbo?
    Fuel pressure regulator yes, but standard injectors are ok for the K04.
    The GT28 i believe needs bigger injectors.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Oct 2006
    I'd change the injectors for K04 upgrade. Do both for GT28.
    Jun 2007
    Quote Originally Posted by Flaps View Post
    why? the KO4 only requires a new fuel regulator
    The TT and S3 with the 225 hp motors have bigger injectors as std. It would seem sensible tome to go for bigger ones if upgrading the turbo to a K04, unless you are not going to be using a 3 inch MAF.
    What you need to know is the desired fuel rate - three factors:
    Injector size, Fuel pressure regulator, and fuel pump.
    Its not much use putting a 5 bar FPR on it as you anly have a 3 bar fuel pump etc etc. You can go to a 4 bar fuel pump (TT / S3) but to be honest - the K04 is happilly fed by stock injectors & 4 bar FPR (with stock pump)
    on our TT kit, we use a 5 bar FPR, 4 bar fuel pump in tank (now as the lift pump), 4 bar fuel pump in line & some pretty big Bosch Motorsport injectors
