Results 1 to 7 of 7
Thread: Fuel cap unlocking
    Mar 2009
    Fuel cap unlocking
    Hi all... just a measly little problem with my new polo (only 2700kms so far!)
    The fuel cap seems to pop open enough when i use the central locking that it will not latch shut when i lock the car without my holding it in the correct position. This is kinda annoying! If anyone has any ideas as to what i am doing wrong/how to fix before i take it to the dealer (which is a little bit of a drive away!) that would be most appreciated!
    May 2009
    you have to press mine to open it, it doesnt 'pop' on its own. Is it a GTi Polo?
    06 > 9N Polo GTi
    Jul 2005
    yep... should have to press them in to open them and press them back in to close before operating the central locking.
    it should not pop open on its own otherwise it will open each time you unlock the car.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Jun 2008
    I know this sounds obvious but might still be worth checking:
    The rubbery stringy thingy that your inside fuel cap dangles from when it's undone sometimes gets all twisted up and if it gets caught in between the outside lid and the bodywork/the black plastic liner bit then the lid won't shut properly, hence popping out. I always make sure the rubbery thing goes well inside the cavity before closing the lid.
    Mar 2009
    Quote Originally Posted by Roodosutaa View Post
    The rubbery stringy thing that your inside fuel cap dangles from when it's undone sometimes gets all twisted up and if it gets caught in between the outside lid and the bodywork/the black plastic liner bit then the lid won't shut properly, hence popping out. I always make sure the rubbery thing goes well inside the cavity before closing the lid.
    Oops!! thats exactly what had happened!
    Thanks Roodosutaa - You're a legend!
    Jun 2008
    Quote Originally Posted by PSY604 View Post
    All good mate - I wouldn't have known if the same thing hadn't happened to me a few times before...
    Sep 2008
    AHA!!! Problem solved. Aren't these forums just great?
