Results 1 to 9 of 9
Thread: Front Strut Top Brace for TDIs
    May 2012
    Perth, WA
    connections are soft, but don't have a good place to relocate the block
    need to extend all the connections to relocate it as well, it's a lot of work
    so anyone tried this bar? no one?
    06 Polo TDi
    Jan 2009
    blankedy
    If you look at the UltraRacing group buy thread, on page 15 there are some photos of the installed product. I think you could probably mount the Vac system to the brace, or move the bracket up an inch or so to find clearance. Solution probably depends on how willing you are to modify whats there or do a little fabricating (or for me, using zip-ties).
    I'm not saying this is the best solution, but the UR braces seem good, I don't think you get nearly as much bracing if you don't use many bolt points.
