Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 117
Thread: Front mount options?
  1. #71
    Sep 2006
    Quote Originally Posted by VWindahouse View Post
    Great info Instigator! And I'm interested to see if anyone in OZ has a go with the Seat Intercooler. Might be interested
    VWthunder did you get the 3" maf and the TIP as part of your package?
    Cheers.
    I bought a nice after market hand made Maf housing, off ebay lol, guy in the states makes them, and yes I got a Black TIP, which is different to the polo one. I had to cut the new TIP up and also cut up my forge one, so it ends up being 3/4 Forge and 1/4 Frankenturbo TIP
  2. #72
    Feb 2007
    Brisvegas
    Ok, thanks for that! Do you have a link for the ebay dude?
    Cheers!
  3. #73
    Jul 2010
    Quote Originally Posted by FLYINGTI View Post
    Hey noone!
    ive talked to one of my mechanic mates, and there into the drag scene and i got them to search my car for what will be good and they said dump pipe wouldnet really do anything for my car, how come?? or is this just bad advise??
    Exhaust was my 2nd favourite mod after the tune. More torquey and much more noisy.
    MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
  4. #74
    Sep 2006
    Cheers!
    Hmmm, it was a while ago, think it was this one
    http://www.ebay.com.au/itm/MAF-3-HOU...item3caef4e43b
  5. #75
    Feb 2007
    Brisvegas
    Quote Originally Posted by vwthunder View Post
    MAF 3" HOUSING MK3 VW CORRADO JETTA GOLF PASSAT AUDI | eBay
    Nice one, thanks mate!
    Instigator, I don't suppose you've come across ready made TIP to handle the 3" MAF housing that is a direct fit for the Polo in your travels??
    Thanks!
  6. #76
    Aug 2009
    Belgium
    got a full milltek exhaust, 2.5" all the way, more than enough, you need more if you go +300Hp.
    after a remap you notice you can get more Hp from it.
    all upgrades don't make that much diffrence on stock engine, once mapped it's another story.
    things that are restrictive on a Polo GTI:
    intake pipe: don't make much diffrence but it will be better (use a seat one if you still have stock airbox)
    Downpipe & CAT: every catalysator is restrictive (get a sportcat or none at all)
    Turbo intake pipe: stock one has a 90° turn where it's going to the turbo, at this turn it's reduced in size (get a Forge one)
    Throtlle body pipe: on LHD cars VW installed a "sound pipe", pretty much useless wich mess up the flow. (Forge needed)
    Intercooler: stock one is to small and sits in a bad place, pretty much anything is better (i prefer seat sport with Forge piping)
    software: get it mapped because stock a polo makes only 0.6bar at his best (best = custom tune)
    fuell pressure regulator: when you do all the above and get it mapped you will need a 4bar one, stock one can't give enough (TT225 & Cupra R)
    if you want i can post pictures of all the restrictive things, when i changed them i took those pictures.
    odd to see the stock Turbo TIP next to one from Forge, or dowpipe next to milltek one, clearly see diffrence in size in all the things.
  7. #77
    Aug 2009
    Belgium
    @VWindahouse: no, i diddn't search after this because i still have the standard MAF.
    but i do believe the TIP from Frankenturbo is made to fit 3" maf.
    if you want i can ask my mate, he has 3" maf so maybe he knows brands that have a TIP that will fit.
    if i may ask, why are you getting 3" maf?
    planning Big Turbo upgrade:p
  8. #78
    Feb 2007
    Brisvegas
    Quote Originally Posted by instigator View Post
    Yeah unfortunately vwthunder said the TIP he got from Franken is not a direct fit and he ended up having to cut it up along with the forge tip to franken up his own!
    And to answer your question about the bigger turbo I must admit after reading all your real world info is mighty tempting mate! Keep it coming.
  9. #79
    Aug 2009
    Belgium
    hahaha, nice going mate, currious te see what turbo you are planning to run.
    any info you need, i'll try and help as much as i can
  10. #80
    May 2011
    CAMPBELLTOWN
    Question!!
    Can u can replacement hoses that you can swap with oem to get better airflow??
