Results 1 to 10 of 10
Thread: Front lip and Springs - Advice
    May 2010
    S.E Melb
    So I received my front lip last week,
    VW Polo 9N3 MK4 FL Bumper Cup Spoiler Lip Sport Valance (eBay item 130435805171 end time 26-Oct-10 07:54:01 AEDST) : Vehicle Parts Accessories
    but i have absolutely nfi how to fit it
    looking at the front bar, the grey strip underneath im assuming has to be taken off, but how?
    can anyone help?
    also, i received my h&r springs today although after some tips from others who have had them installed, are there any surprises i should be prepared for? ive changed springs in a vx commodore, and an astra h (2007), so i would assume the concept is the same, but just wanna be sure that im not gunna run into any issues!
    cheers
    MY07 Polo GTi
    Last run - 114.8kw atw
    Winton - 1:52.7130
    Mar 2008
    For golfs and my pug, you just drill holes into the bumper and lip, then stick it on and cut the excess bits off the edges near the wheels. It's a bit of a hack job but works a treat.
    Might be different for the Polo's but I doubt it.
    Feb 2008
    Just drill pilot holes once you have centered it and bent it to the form you want, the screw it on. Trip down the ends once fitted. I will say that I trimmed down the 2 center posts on the spoiler till they were flush with the tabs in the center of the posts.
    Springs are easy to fit. Both rear springs shouldn't take more than 20 minutes to fit, but on the front I pulled the drive shafts off the hub and disconnected the ball joints from the lower suspension so I had more room to pull the struts out. Doing the springs on the polo was the first time I had attempted to lower a car, and all up it took me about 4 hours. Mind you, I had access to a full workshop, and a 2 post hoist....
    May 2010
    S.E Melb
    I probably won't go as far as pulling the drive shafts out for the struts and I'll have a bit of help so shouldn't take too long!
    MY07 Polo GTi
    Winton - 1:52.7130
    Jan 2009
    The front end can be a PITA, there's a thread on here (would need to search) which has a "how to" guide. There's a specific tool that would have made life a lot easier, I started without the tool thinking it can't be that hard, but gave up. The tool is like a beefed up circlip plyer to remove the strut from wheel/hub assembly. Drivers side is generally more difficult from my experience and feedback, so perhaps start with that one.
    May 2009
    S.E. Melb Vic
    I have all the spring collapsing tools needed to change struts and the front lip is easy as well come on over and I will help you.
    Cheers ssman
    Jan 2010
    May 2010
    S.E Melb
    Quote Originally Posted by ssman View Post
    Cheers ssman
    Sounds good Van, I have booked it in to have the springs fitted this week, would you be free sometime next week / weekend to help me with the lip by any chance??
    MY07 Polo GTi
    Winton - 1:52.7130
    Oct 2010
    Melbourne, VIC
    You need to get the lip on quick smart - your Gti looked so lame next to Dave_GTi's
    Just kidding It looked just beautiful pulling out of those hairpins, yesterday
    May 2010
    S.E Melb
    Well when I can figure out how to I will
    MY07 Polo GTi
    Winton - 1:52.7130
