Originally Posted by
noone
My last works included brakes, sway, coilovers and control arm bushes. they make the car handle very differently and I have mentioned before (eg in the AP Coilover review thread) that I cant say exactly what changes had what effect as it was all done at once.
Which is why you have no clue so as to what to change more or less of to make it faster.
Cars need to be modified in steps. Thus you know what worked or didn't, and by doing so, you'll learn more.
The Mini at home now has (With an LSD i'll add)
Front:
3.5 degrees negative
6 degrees castor
2mm toe out
Koni re-valved dampers
(no sway)
Rear:
2 degrees negative
1mm toe in
(no sway)
And this thing skips around Mallala all day very fast, and is still nice enough to drive on the street.
The issue with adjusting sway bars is that the rear one will make the front bite more, and the front sway bar makes the rear bite more. You've added an anomoly into the system by adding a rear sway bar in any case.
Every adjustment works on the opposite corner to which you adjust.
Go find a nice quiet backroad. Drive it again and again and again. Change something. Drive it again. See what you think - You'll learn quick enough.
But any monkey can still ruin a fast car - YOU have to be the fast bit.
Read and learn. That website i linked above is the best one i've seen. I suggest you learn it.
Cheap, Fast, Reliable. Choose two.
