Results 1 to 10 of 15
Thread: Front End Knock/Clunk
    Jun 2007
    Brunswick, Victoria
    I know I seen someone also discussing a similar problem with their Polo GTi but I cant find the post for the life of me.
    I am getting a clunk/knocking sound from the drivers side front end when taking corners 20-25kmh +. I dropped it off to the dealer under warranty but they couldnt find anything out of character - not sure how hard they tried.
    I know its not right and this needs to be addressed.
    Any suggestions on possible causes/fixes would be greatly appreciated.
    Thanks
    Jan 2007
    http://www.vwwatercooled.org.au/newf...?t=2693&page=3 from 5th post down and
    http://www.vwwatercooled.org.au/newf...ead.php?t=5768
    I have had shocks replaced didnt fix it... its more common than i thought, I think a characteristic of some crappy part of the car that no dealer can identify... the biggest prob is getting a dealer to hear it, cos when you take it there it wont make the noise for them
    ya i do have that problem too!
    when i bring it to dealer it won't make any noise...
    2013 4Motion "BLACK BEAR"
    http://blackbeartiguan.blogspot.hk//
    beefa Guest
    I find i can replicate it pretty consitantly by driving into a driveway with a fair amount of left hand lock at a brisk walking pace.
    If you can do this too, then there is a good chance of being able to replicate this at the dealerships.
    Good luck
    Oct 2006
    Quote Originally Posted by beefa View Post
    Good luck
    x 2. I've also replaced my suspension with coilovers. So it has to be somehting to do with the brakes, mounts or driveshaft?
    Jun 2007
    Quote Originally Posted by Flaps View Post
    Maybe it's time to replace those as well!! BRAKE upgrade!!!
    beefa Guest
    front sway bar mounts or tierods maybe ..
    Mar 2006
    South Hobart Tasmania
    S3 brakes and new swaybar still does it i find its there more when cold eg cold mornings.
    Does it happen with ESP turned off?
    Jun 2007
    Brunswick, Victoria
    Very good question. Ill try it with ESP off.
