Results 1 to 10 of 12
Thread: Freaking Awesome site with details on the Polo's construction, inclues part numbers
    Jan 2009
    blankedy
    2007 Polo Lim.(Stufenh./Sedan) Parts
    Awesome! Please help me work out how to save it so we still have it if they take the site down...
    Jul 2010
    Bulleen, Melb, Aus
    Hey ben, cool site. Can you link that site where the guy has guides on how to take off the trimming etc. Ive seen you link it a few times.
    As to your question.. Few things. wget.. webstripper..maybe httrack would be easiest (Download HTTrack Website Copier 3.44-1 - HTTrack Website Copier - Offline Browser)
    Nov 2008
    Ben, I got it down with PageNest (new name for Webstripper) as HTTrack kept giving me errrors. Not hard to use and it all seems to be there.
    Here's a link to the program
    Jul 2005
    Easy way to save;
    1. Right click on the page you want to save.
    2. Select "Copy image".
    3. Open the "Paint" program that comes with every computer.
    4. In the "Edit" tab, select "Paste".
    5. Then select "Save As" to save on your computer or external hard drive.
    It works for me.
    Maris
    Jan 2009
    blankedy
    Thanks guys, I tried to strip, but the site shut me down, likely thinking I was spamming it. It's a good resource.
    Adelaide hills, SA
    You can just save the section you've opened; from the menu select "save as" and it's done.
    Jan 2009
    blankedy
    Yeah, I want the whole thing in case they pull it down. Cheers
    Nov 2008
    If you want a copy of the website - I ripped it all down - I zipped it and you can download it from this LINK
    If you want to run it up as it appears on the web ... click on the index.php.0.html file and that will kick it off and let it run from your PC locally, I've had a look and it appears the menus and pictures are all linked properly and working.
    If you just want the images you can pull them out of one of the folders within the file once you've downloaded it.
    Jan 2009
    blankedy
    Thanks man! I'll check it out...
    Jan 2009
    blankedy
    Lots there, but you had the same issue as I did. Some pages don't show the content, only "Going to need to slow you down for a bit."
