Quattro Motors recently installed a deiselgeek short shifter, which I'd purchased form the US directly, so thats not stopping them
2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
T Go
MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
I suppose because of the fitment issue & the risk of damaging that pipe if you dont do it properly, they would rather not do it unless do it properly.
I suppose the big thing is how much do you expect to pay to have it done?
(Just a guess - to do it with the pipe off would probably be 4 hours @ workshop rate - so $400 to $500 ???????)
Only my guess though - I have no idea otherwise.
I fitted a couple and they are an absolute bugger to do (with my size arms thats for sure).
It took me 3 hours to fit the TIP myself. It isn't hard job, but it can be a bit of a bastard. I fond if you removed the 6mm Allen bolt, and the 3 13mm bolts that hold in the transmission linkage(make sure the car is in neutral), that this gives you enough room to play around with to get the old TIP off and the new TIP on.
This is my install post...
http://www.vwwatercooled.org.au/newf...&postcount=549
I confirm that this method works as i did mine reffering to it !
A great help i have to say
Shaneth talked about too
And i've posted pics in my thread to complete the install post of Blitzen.
On this pic, you see exactly where are screwed the 2 bolts you have to unscrew as you can go ahead with the install :
Just be carefull to not scratched the coolant pipe near the TIP !
I scratched mine when i remove one of the clamps on the stock TIP... :
Cheers,
Quest
Quest, in your photo, the turbo has code number - 5304 101 .... , can you confirm what the whole number is? Just want to work out which turbo your car is running
Last edited by Quest; 09-12-2008 at 07:14 PM. Reason: Neil was kind with me...lol ! ;-)
