Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Forge TIP in WA
    Jan 2008
    Canning Vale, Perth, WA
    Quattro Motors recently installed a deiselgeek short shifter, which I'd purchased form the US directly, so thats not stopping them
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Jun 2007
    Perth
    You tried Joe at Golfwagen?
    Quote Originally Posted by T Go View Post
    Hey Guys,
    Im having problems finding a place/person to fit my Forge TIP.
    Ive been to a couple of places and they either say its the wrong part or they cant do it...
    Ive checked the part with people on the forum already, and its the right one.
    Its starting to get hella frustrating...
    Does anyone in WA have one fitted??
    RIP Ruby Thunder (1994 VR6), now driving the GF's MK IV 1.6
    Jun 2008
    Perth
    Just for info - to get the factory unit off the turbo, you are supposed to drain the coolant & remove the hard water line that runs past the turbo intake pipe.
    If you do not remove this pipe, you run a big risk of damaging it and causing a coolant leak. Those who have done this job will know this pipe & the difficulty in getting around it. I know for a fact that several of my customers have had to order a new pipe after busting theirs!
    Its a real PITA, there are two 6mm bolts that hold it to the block and there is pretty much no slack or extra hose to get it out of the way.
    Just take care in that area!
    Hey Guy,
    Do you understand why Quattro Motors would not install these TIP's?
    I use them for all my APR stuff but these appears a bit beyond them?
    Mar 2008
    Canning Vale, WA
    Quote Originally Posted by runamuk View Post
    Just gave him a call and hes gonna have a look at it this week (hopefully).
    Thanks for the help on that 1, lets hope it works!
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
    I suppose because of the fitment issue & the risk of damaging that pipe if you dont do it properly, they would rather not do it unless do it properly.
    I suppose the big thing is how much do you expect to pay to have it done?
    (Just a guess - to do it with the pipe off would probably be 4 hours @ workshop rate - so $400 to $500 ???????)
    Only my guess though - I have no idea otherwise.
    I fitted a couple and they are an absolute bugger to do (with my size arms thats for sure).
    Feb 2008
    It took me 3 hours to fit the TIP myself. It isn't hard job, but it can be a bit of a bastard. I fond if you removed the 6mm Allen bolt, and the 3 13mm bolts that hold in the transmission linkage(make sure the car is in neutral), that this gives you enough room to play around with to get the old TIP off and the new TIP on.
    This is my install post...
    http://www.vwwatercooled.org.au/newf...&postcount=549
    Jun 2008
    New Caledonia
    Quote Originally Posted by Chipped View Post
    Thanks Quest, we may have to no mechanic here has the courage!!
    It could be my Christmas break task...my hands are shaking already.
    I was and i am in the same situation in NC ! That's why i had no choice !
    The best is to find one mechanic which works with passion....and i think i have find one to fit my Christmas gift (Billies + H&R)...at last
    Jun 2008
    New Caledonia
    Quote Originally Posted by Blitzen View Post
    I confirm that this method works as i did mine reffering to it !
    A great help i have to say
    Shaneth talked about too
    And i've posted pics in my thread to complete the install post of Blitzen.
    On this pic, you see exactly where are screwed the 2 bolts you have to unscrew as you can go ahead with the install :
    Just be carefull to not scratched the coolant pipe near the TIP !
    I scratched mine when i remove one of the clamps on the stock TIP... :
    Cheers,
    Quest
    Jun 2007
    Quest, in your photo, the turbo has code number - 5304 101 .... , can you confirm what the whole number is? Just want to work out which turbo your car is running
    Jun 2008
    New Caledonia
    Quote Originally Posted by GT3 View Post
    http://www.vwwatercooled.org.au/newf...ad.php?t=23709
    Last edited by Quest; 09-12-2008 at 07:14 PM. Reason: Neil was kind with me...lol ! ;-)
