Results 11 to 20 of 26
Thread: Forge TIP
    Feb 2008
    Quote Originally Posted by vwthunder View Post
    This is APR's TIP off the ECS Site for the MK4 GTI
    Does it look the same as yours
    I have seen this particular item in the flesh, and although it is very similar to the Polo GTI TIP, I think one of the outlet points is missing from the APR MK4 TIP item, and i think one of the outlets are a different size.
    Personally, I think you are better off buying off the Forge site. I think this is where you will get the product that is known to fit your car, and you cut out a mark up from the middle man.
    Also talk to Guy Harding, as he sells the APR TIP, and knows both the Polo and MK4 Golf GTI's.
    Both items are going to be a similar price once they are shipped, but I know for a fact that the Forge one fits.
    Up to you though.
    Jan 2009
    sunshine coast
    http://www.forgemotorsport.co.uk/con...uct=FMINDIBFR4
    nope not the same . its a pain to get in but i wouldnt consider myself a very mechanically minded person but i did it. the most dificult part is losening the bolt for the bracket that holds (i think its water) the pipe onto the side of the engine block its not so dificult getting it off but getting it back on can be a pain. you may also notice when you do finally get it all on that this tube will partially kink the tip a lil bit. some have left it be, others have slightly bent the black water pipe so it doesnt kink it (your choice)the risk is really up to you, i dont think anyone has reported anything detramental to just leaving it be. if you do run into trouble quite a few of us have done the tip ourselves and we may be able to help.
    Jan 2008
    Cremorne, Melbourne
    MK4 GTI and Polo GTI Turbo Inlet Pipe's are different and will not fit on the other car.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Jan 2009
    blankedy
    TIP review
    I installed my TIP and Throttle Body hose yesterday, went for a drive today and thought I'd do a little write up on my thoughts.
    Install:
    Complete PITA. If you are not confident, pay someone else to do it. It took me about 4 hours all up, I was exhausted afterwards. Blitzens writeup is very helpful.
    Testing:
    Before I start telling you what I think, its important to note that I have already done some intake mods and have a 2.5" dump pipe fitted. These findings will be very different on cars without this level of airflow improvement.
    I'm running APR Stage 1, V2 tune. The more I read about different tuning, the more differences I find in the effects of mods. Different tunes may bring out the best or make little difference with this mod.
    Noise:
    There is more turbo spool noise. Its not a massive change, but is noticeable.
    Power delivery:
    The turbo seems to spool more easily when the boost is coming on. 1st gear I didn't really play with as its too short. 2nd gear feels like the boost comes on at lower revs, making low RPM gear changes more fluid and less lacking in power. 3,4&5th gear feel much nicer. I note that I am more comforable to leave the car in a gear at lower revs (below 2.7k) as there is more power there than before.
    I have not dyno'd my car, but feel more power is available at lower revs. For my style of driving (medium revs) the Power is comfortable and the power delivery suits the car.
    I can't say much on the top end (redline) RPM. Others have commented it helps, but the v2 tune does not suit this sort of RPM as well as other tunes (even the v1 tune) and I don't drive my car with high RPM so can't comment.
    I feel the airflow is improved which requires less exhaust force to pull the air through the Intake piping. I assume this is why there is a more linear power. The turbo feels / sounds like it starts at lower RPM or is more effective at lower RPM. There is a placebo effect of the greater noise making me feel there is more air flow, so I'm trying to base this on feel.
    Recomendations:
    I am happy with this mod. It works well with my other mods, chip and driving style.
    I would NOT recommend this to people who:
    - Have not had the GTI chipped
    - Have not installed the PD160, and panel or Pod filter
    - Have stock diverter and dump pipe. These are IMO better places to spend your money before the TIP. Also FMIC if you are in a hot area.
    Oct 2006
    Install:
    Testing:
    Noise:
    Power delivery:
    Recomendations:
    I have to comment a lil here..
    Firstly lets start with this video to see in fact the differences on the TIP's on the 1.8t's in general http://forgemotorsport.com/intake.mpg
    Next, 3 mods that makes any 1.8t noticable for amount of money spent.
    Downpipe (exhaust NOT needed for a MASSIVE increase. hiflow cat *definitely* not and if you think so you're a plain idiot (as in whoever not specifically lol)
    Chip (whatever brand you choose) + N75J/H
    Diverter only has to be changed as he cant hold so much boost constantly and eventually gives in. TT one can be used, but GFB & Baileys would be my top 2 pics other then the apr.
    and the TIP. It will benefit from 4000rpm on wards where a normal stock tip creases and gives in where the forge/other brands due to shape/thickness of silicone holds shape and you feel a lot more boost all the way through.
    You do NOT need some crazy airfilter, oem vw filter in comparison was under 2kw which is very minimal for day to day driving. (dyno proven). However if you run a decent intake system (not a snorkel but actual something from the front end you will get the same from an oem as a pipercross or bmc)
    Downpipe = quicker spool esp from lower rpm, bit more sound and definitely more power overall.
    Chip = obvious answer
    TIP = smoother turbo breathing
    Throttle Body hose, yes works but not something you REALLY need until you are at the end of your mods list although might as well get it at the same time to save shipping costs.
    Just my 2psi after playing endlessly with mine and tuning it out as well as others.
    Feb 2008
    Just on the TT diverter valve...I have looked high and low for one of these, and have been told more than once (including by JMAC) that the standard Polo GTI DV and the TT DV share the same part number....
    I have the Forge 007 DV with the 17-22 PSI spring in it now, but I have never found a TT DV.
    Oct 2006
    Quote Originally Posted by Blitzen View Post
    i found 2? lol .. gone now tho, 1 lost and 1 i sold i think.. but if same part number, go figure.
    like the ttrs being a t4 transporter engine.. lol
    the baileys one has a great feel. proble mwith the forge one i found was that every spring gives you a different feel when boost comes on. 1 spring would hold more boost in certain gear/rev range more then another, so i changed.. gfb or baileys i would recommend personally from exp but at the end of the day same sheet! lol
    Aug 2007
    Quote(You do NOT need some crazy airfilter, oem vw filter in comparison was under 2kw which is very minimal for day to day driving. (dyno proven). However if you run a decent intake system (not a snorkel but actual something from the front end you will get the same from an oem as a pipercross or bmc)
    Yep agree here, i have many convos about this, but its really each to their own at the end of the day, some like the throat noise where ive got over that
    Interesting about the N75, there is a few variants with different results too, good to hear the feedback here.
    Jmac
    Alba European
    Jan 2009
    blankedy
    Thanks for the input Pierre.
    The Polo stock intake is more restrictive than the Mk4 as well, so further improvement again.
    Good point about the Throttle body hose, I didn't really touch on that, was only really commenting about the TIP (well, I assume, did them at the same time).
    I ran the N75J for a while, boost was more linear. I preferred the Stock N75 with my setup and tune, so have a J sitting around gathering dust, Might try it again as I have not had it on since the FMIC and TIP.
    Oct 2009
    Canberra
    Where can I buy the N75J? Is this an original part from VW?
    Current:
    2023 Mk2 Tiguan R - Lapiz Blue
    2015 Mk7 Golf R Wolfsburg - Limestone Grey: Stage 2
    Gone but not forgotten: 2008 Polo GTI Shadow Blue
