Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 132
Thread: Forge Strut Brace Group Buy
  1. #121
    Sep 2006
    Tweed Heads
    Quote Originally Posted by DaveMack View Post
    You're just too rough on your poor lil Pogo, Eddy. My strut brace is fine.
    Dave
    Hoyhoy.
    Dave have you tried adjusting the knuckle for curiosty sake.
    You can't see when the threads are gone , only feel it when adjusting.
    Hooroo.
  2. #122
    May 2007
    Yea, happened to me too. I think i over tightened it... then as its pulls itself together instead of stopping, it just melds together until you can only adjust half a turn each way. Still works.... just use it as non adjustable, which it probably should have been in the first place.
  3. #123
    May 2007
    Burleigh Heads, Qld
    Interesting.
    I'll check mine. I think the effective shortening of the bolt could be a problem.
    I've thought about getting half inch or so longer bolts to hold the brace down.
    I've noticed a couple of small metal filings on the rubber hose under where the screw thread adjustment is. Will check it out.
  4. #124
    Sep 2006
    Brisvegas
    Ive had mine off no problems and if you look through the seat ibiza mk4 secrion of the forge catalogue the strut brace still says its for the polo as well. Not sure but the site has chnged since i was online last and maybe they havent linked it yet,
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
  5. #125
    Mar 2007
    Quote Originally Posted by Eddy View Post
    Hoyhoy.
    I've had mine off to put the K&N filter in, Eddy ... no problems.
    Dave
  6. #126
    Sep 2006
    Tweed Heads
    Dave
    Hoyhoy.
    Dave, me think that the KW-V3's would put a lot more of a load on things. Plus I'm not as old as you & get 600KM's/ tank.,,,,,,,,,,,
    Hooroo.
  7. #127
    Sep 2006
    Tweed Heads
    Quote Originally Posted by shaneth View Post
    Hoyhoy.
    Shane I'm not putting any blame on you what-so-ever Bud,,,. I now know that mine is a lot stronger than in the standard form.
    Hooroo.
  8. #128
    Sep 2006
    Brisvegas
    Hoyhoy.
    i know eddy. just had mine off the other day so i thought i would add mine to the list. it would be interesting to see if anyone else had the problem.
    Have a Look
    CUSTOM CODE
    Phase 2
  9. #129
    May 2007
    Mine came off and on a couple of times fine. But i just overtighened it one time, and didn't want to come off. Still works, just take it off at the ends, as a solid piece.
  10. #130
    Mar 2007
    Hoyhoy.
    You hitting the 'turps' again, Eddy?
    Dave
