my brother has a strut brace on his s14.. its very solid and has a bit of weight about it.
The forge one felt light as a feather, the metal seems very thin. When i tried to bend it, guess what happened. it bent lol
where did it bend?? I cant say i tried bending it.![]()
straight in the middle. where its flattened out.
just thought that being a part which is supposed to strengthen the chassis it would be made of a strong material???
Howeverits a nice bit of eye candy for under the bonnet
Certainly made a very positive difference to the steering of my Pogo ... far more direct.
Dave
That seems like an unusual thing to do...
Pretty sure strut braces are designed for rigidity between the struts...
i.e.
<------------------------- In this direction ------------------------->
Just exactly would you try to bend a brand new strut brace in a direction it's not engineered to have to provide strength???
The analogy is the same as an egg. While you could break the shell with a minimum of pressure on the sides, if you tried to break it by applying pressure end to end, it is damn near impossible. Something that is engineered correctly does not need to weigh a ton (how thin is an egg shell, and yet in the right direction it is stronger than you will ever be). Why would the company overengineer the brace unnecessarily?
JHN
Canadian dubs coming to VWwA soon
I've had mine on for a week or so now and I love it. It somehow helps me with gaining traction through the front wheels, especially whist cornering. More solid feel through the steering wheel as well. Good mod IMO!![]()
Fitted mine tonight.
Takes 5-10 minutes, super easy.
Dont know if its made any improvement to handling, but it has given steering a little more life and response
