Page 19 of 20 FirstFirst ... 917181920 LastLast
Results 181 to 190 of 199
Thread: Forge Short Shift Kit - Group Buy
  1. #181
    Oct 2010
    Melbourne, VIC
    Sorry leegil, that happens not to be the case - you can ask the UK seller or the local distributor, John, if you like. The SRS-II is a rebadged Alientech PowerGate S, just like my Viezu V-Switch, and it gets locked to the car when you do the original ECU download.
    John or DNA Tuning in the UK can reset it but they would only do it if you are on-selling the unit. Once this has been done and another car downloaded, you would not be able to use the SRS-II to reflash your car.
    See Alientech - Powergate II
  2. #182
    Nov 2010
    Thanks for clarifying. I thought it could but I am obviously mistaken. Never tried (as I only have 1 tune). Just thought it could be copied through like a USB key. I do know that I can have more than one tune to store on it but was not sure that it was locked to my car.
  3. #183
    Oct 2010
    Melbourne, VIC
    No prob - I just wouldn't want you to make a promise to someone that you couldn't fulfill.
    As for ACT, short shifting Polos, check with Blitzen or Smead - I believe they are also Capitalist Territorians and have the Forge short shifter.
  4. #184
    Nov 2010
    Yeah, Blitzen is helping me out on Wednesday. Once I learn how to do it, and if I have the correct tools in my arsenal, then more than happy to help others out as well.
  5. #185
    Oct 2010
    Melbourne, VIC
    I would still advise you to heat the original shifter up with a heat gun until it is uncomfotable to touch to loosen it off from the splines (then use a garden glove to pull it off). The battery cage is trickiest part but Blitzen will show you the trick in getting it off.
  6. #186
    Feb 2008
    I just took the air filter box out... This gives heaps of swinging room.
  7. #187
    Jan 2009
    blankedy
    You can do it without moving either, disconnecting the 2 SAI hoses gives enough access (visibility is poor tho).
  8. #188
    Nov 2010
    This is why I sought assistance...sounds like three different approaches. Simplicity is the key for me I cannot even recognise the bits you are talking about. Thank heavens for a good community.
  9. #189
    Oct 2009
    Canberra ACT
    Quote Originally Posted by Blitzen View Post
    Yeah Airbox is the way to do it. Also removed my PD 160 intake for a little extra room
    06 VW 9N3 Polo GTI - Reflex Silver Leather/OEM Colour coded S/guard/OEM Lower Honeycombe Grille/NSP Boost Gauge/APR Stage 1+,Dogbone & DP/K&N filter/Forge s/shift,DV008 & Strut brace/PD 160/Samco camo TIP/Whitline RSB/FK AK's/17 x 8 Oettiger RE's/Alpine Head Unit & Sony Amp. OEM+FTW
  10. #190
    Nov 2010
    Here's the update:
    42DD was installed with Blitzen's help. First attempt went very bad as we did not mark the rod and this led to the H-pattern moving towards the bottom right (barely got into 5th gear). Once I worked out what was the cause and how to rectify it, we took another go a few days later with full success. Moral of the story...mark the rod before you remove the plastic jaws to insert the bushings. Note that markings on the rod are not threads, but circular grooves as markers and grip for the jaws. Special thanks to Blitzen and also Greg Roles for being 'on call' for the second rectification if required (was not required). If you do stuff up the rod length, it is easier to have 2 persons working on it (one adjusting and other moving the lever in the car to tell you if there is improvement -saves in/out of the car).
    The short shifter was an absolute pain. Blitzen and myself could not remove it off the car spline. We had no leverage without removing the battery box (which we did not do). Ultimately I took it to Canberra VW Centre (CVWC) to install when they were doing the minor service and replacing the radiator. Damn radiator cores leaking by 70K km is ridiculous (my '95 Hyundai Excel went 160K km without issue). Back to the story, they had the leverage on either side of the shifter to apply force and 'wiggle' it off. Good work by Dean at CVWC.
    The feel:
    -42DD by itself was very direct and removed a lot of the 'rubber bounce' of OEM shifter. Shifting effort was just the same (no additional effort).
    -Short shifter makes it a little more effort but also 'notchier'. The shortest setting is to my satsfaction, although I would have preferred to go even shorter if possible .
    It all feels good now.
