Seems the Polo's only differ on the vertical mechansim, all models in MKV run the MK4 bushings on the flat mechanism you are replacing with the Forge short shift. You will need to modify these B6FB52 bushes slightly to get them to fit the Forge shafts according to Tommy. The shafts must be slightly bigger than OEM, so will need a slight enlargening of the hole for one of the shafts apparently.
The earlier model up to mid 2007 runs the HWY box and uses the rest of the MK4 kit just fine. The later MY08-09 runs an O2A gearbox, and uses the vertical bushings, pivot and shaft rebuild out of the 08-09 6 speed Golf kit. I've used up my stock on hand fixing up the first three Polo guys on here I dealt with, the rest will be ordered in and take about a week. I have extra bushes coming back from my test pilots, so may be able to help a few more of you out before the main delivery arrives.
To check your gearbox version...
Grab your owners manual, and go to the service section here:
The next page is your car's detail sticker, and your gearbox is listed here ( red arrow ):
HWY is the MK4 bushing kit. O2A is the later pivot rebuild hybrid kit.
