That's excellent news!!! I am uploading my bush install video to you tube right now, bit late for you Tommy, but may help everyone else.
Sounds like you need to slightly adjust the vertical mech cable length, and I'll have a video on doing that up in the next day or so. Basically making the cable end longer, moves the gearstick away from you, and making it shorter moves the stick to the left. I found just one notch on the cable end shaft made all the difference with notchiness. It's like the rubber OEM bushes have enough slop to allow the gears to "deflect" into place if the alignment isn't quite right, whereas having them tight you need to fine tune the H pattern alignment. BEFORE anyone tries that, mark the steel shaft with a nikko pen so you know where you started from, as just one "tooth" makes a big difference, and the stock setting is always perfect / close to!
Once I find out which bushes you Polo guys need, I'll most likely need to get a special order in, as it sounds like the 2008-2009 Polo kit will be a frankenstein mix of a few bushes from 42DD, and I only have about 4 kits of each model in stock at any point in time. Once Tommy lets me know the hole enlargement, I might be able to get a specific drill etc to prefab them before sending.
Anyone with a 2007 or earlier with the HWY gearbox can just run the MK4 kit, you have it easy, and I have more of them landing next week.
