Page 6 of 20 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 199
Thread: Forge Short Shift Kit - Group Buy
  1. #51
    Feb 2008
    Perth, WA
    im not attempting either with my desk jockey hands...will have my mechanic install both
  2. #52
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by vwthunder View Post
    the 42DD bushes have to be drilled out a little.
    I found a drill bit which was like .001mm bigger than the hole in the bush, sprayed a bit of WD40 and it took like 4 seconds to get the drill bit through
    Could you take a poofteenth off the Forge shift pins on a lathe to get the correct clearance?
  3. #53
    Sep 2006
    I think it is easier to take it off the bush, as it only takes a few seconds
  4. #54
    Jan 2008
    Sunshine Coast
    Either works, but have you got a firm response from Forge about the pin size vs stock?
    Here's how fitment works for you guys:
    MKIV 5/6speed MY02-05 (42-455-001) easy install, just push in bushes.
    MKV 5 speed MY06-07 (42-455-011) easy install, just push in bushes.
    MKV 5 speed MY08-09 (42-455-013) harder install with extra pivot rebuild ( which is still optional ) ( see pic )
    MKV 6 speed MY06 (42-455-005) easy install.
    MKV 6 speed MY07 (42-455-007) easy install.
    MKV 6 speed MY08-09 (42-455-009) harder install with extra pivot rebuild ( can be optional )
    So any of you with 08/09 models, you have the more complex kit with the drill bit, and whilst you also just push in metal bushes, you are best to rebuild the plastic pivot. That said, if you just want the bushes and forget the pivot step, I can cater for that too, and do a bush only 08/09 kit. I'm touching up the fitment video, and will post on this thread later today.
    Fitting the "easy install" bushes, is well, very easy!
    Here's the 42DD tech page, I'm still adding all the tech stuff to my site.
    42 Draft Designs
  5. #55
    Jan 2008
    Sunshine Coast
    Hold up on ordering bushes people, still trying to sort out exactly which one fits the side to side in the MY08/09. The picture above is the Golf MY08-09 6 speed kit, but is virtually the same as the MY08-09 5speed one with the rectangle bushes. Seems the MY08-09 Polo GTI has all round bushes. The info 42DD are giving from the States possibly suit our Aussie cars, and I have a few Polo people who ordered bushes in the last groupbuy that have now worked out what they were advised directly from 42DD hasn't fitted on one half. Stay tuned, I'll sort it!
    Also I haven't sent anyone the video, as the Polo kit is a LOT less complex than the Golf kit I made a video of, you do still rebuild the pivot a little, but nothing like the Golf version. Man, I'm learning Polo at a great rate of knots!
  6. #56
    Apr 2010
    Hi Guys,
    Just an update on the short shifter kit. I'm waiting for bank details from Rennenhaus. I will pass these onto those participating in the group buy as required. Once you have transferred the money, please PM me with your name and delivery address.
  7. #57
    Feb 2008
    Perth, WA
    Quote Originally Posted by End User View Post
    Hi Guys,
    So are we transfering coin to yourself End User or directly to Rennenhaus?
  8. #58
    Apr 2010
    Quote Originally Posted by Chuck View Post
    Money will go to Rennenhaus. Rennenhaus will place order.
    I will collate delivery addresses and pass these onto Rennenhaus.
  9. #59
    Feb 2008
    When are they going to require the money?
  10. #60
    Jan 2008
    Sunshine Coast
    OK have just been speaking with 42DD, and the bottom line is they thought the MK4 -001 kit suits up to MY07 ( correct for the HWY box ), and the 5S MY08-09 -013 kit was suitable for the later MKV Polo ( with the 02A box ). Feedback from Kangfu is that this doesn't fit on the plastic vertical shift mechanism that controls the side to side gearstick movement on the 08-09. I will be sending him ALL the round bushes I have to see if he can work out the ones that fit, as well as another 09 Polo customer who got a MK4 -001 kit direct from 42DD and wanted to order more from me. Between the two of these guys we should come up with a world first late model Polo solution! I will get in a special order for the groupbuy and 42DD are keen to assist getting it correct.
    Anyone out there with an incorrect set from either myself ( from the initial buy in ) or from 42DD themselves direct, please get onto me once a solution is sorted and I will swap out the correct bushes for free.
    Sorry for the delay everyone, seems we are pioneering down under yet again!
