Getting on to the fitting, well it was easy for me as I dont have my battery etc in the way, if anyone has the 42DD solid bushes they will know.
Once you can access the part, all that needs to be done it to remove 2 clips and it should come off, actually it was a bit hard to get it off as it has been on for a while. The forge instructions say to rock it back and forth and it will come off, and it does.
I would reccomend doing the 42DD bushes at the same time as it is not as much work, as your half way there. PM Greg Roles if you want some
