Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Forge 008 Diverter - Interest in group buy?
  1. #21
    Jan 2010
    Yes, please do.
    Please let us all know the difference between 007 & 008. Sound clip would be great!
  2. #22
    Jan 2009
    blankedy
    Download of crappy audio file
    Diverter works well. I don't know if i'm holding any more boost, but the unit works well. With my setup you can hear backing off the throttle from 2000rpm, the pod filter setup makes it quite audible.
    The old (splitter) and the new (008 )
    Started with the Yellow spring and 1 washer, seemed fine. Tried 3 washers, sound became quite whistly which I assume is the air struggling to move past the valve. I've backed off to 2 springs, which seems to be a compromise of both
    From what I gather (reverse engineering), the role of the vacuum from the intake manifold plays a greater role than I had originally thought.
    If you try to press the valve open, like the boost does, it takes a lot of effort. If you suck on the vacuum nipple (ha!) you can feel it open reasonably easily.
    The sound of my Forge Splitter Valve and the 1 and 3 shim setups with the yellow spring in the 008 all sound a little different, this may sort of make some sense:
    Splitter: coooooh
    008 - 1 spring: cah
    008 - 3 spring: tssew
    make sense now?
    All in all, its always nice to have a new toy. I'll reset my ECU sometime and go for a fun drive, see if I notice any difference in a harder driving environment. As the noise of each change is more distinct, I'm likely to go back to the stock airbox so I don't feel like cringing from the noise I now associate with an EVO more than WRX or Skyline. Not a massive difference, but just the mental association when I hear it. Its not THAT loud, but driving in suburbia, shifting at 2500 rpm, it does seem a little funny to have it 'tssew'ing at the passers by...
  3. #23
    Eltham, Victoria
    Splitter: coooooh
    008 - 1 spring: cah
    make sense now?
    Million dollar question: would you say it's a better design and overall product in comparison to the 007?
  4. #24
    Jan 2009
    blankedy
    I don't have one... I've not seen one in action. I had the splitter, not the 007.
    Logic says that it is a improved design, but there were lots of people happy with the 007.
    My only comment on the 007, is if you have not changed the spring from the stock one, get yourselves the spring kit and see of that holds more boost.
