Page 8 of 16 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 159
Thread: ford mondeo drop links
  1. #71
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by MissVuks View Post
    LOLLLL Rhys, what exactly are the drop links? can you explain the benefits of it?? yes i know stupid question but I've never heard of them
    this should sum it up for you
    Ford Mondeo drop links (2000-2003) fit and work perfectly on the Polo 9n3 GTI - lifting the ARB clear of the drive shafts on lowered cars..
    Since I lowered using the H&R springs.. more knocks could be heard from the front.. when travelling slowly over bumpy roads....
    For sure my standard drop links could have been worn.. but the Mondeo ones are slightly shorter so pulling the ARB out of the way...
    Front is now much tighter.. I've been driving over all my close-by speed bumps (they are close and loads of them) ... and all over my closest typically pitted roads... not a single rattle or bang noise..
    and a piccie for pleasure, we all like piccies
    [/QUOTE]
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  2. #72
    Jan 2009
    blankedy
    So, for all interested, the ones I had installed were from UK Ebay.
    Listing came up as: FORD MONDEO MK3 FRONT ANTI ROLL BAR DROP LINK RODS x 2
    Listed to fit 2000-2008 Mondeo's.
    Make sure they are the front ones.
    Here is my non technical / likely imperfect explanation of what they do and why they are a good idea:
    - When the car is dropped with coilovers / lower springs, the drop links are no longer keeping the front Sway bar / anti lift bar in its correct position.
    - I feel that since having changed them, the front end is a bit sharper (but have done RSB at same time, so can't really be 100%).
    - Knocking and general front end noises when going over bumps and cornering reduced (back to just a noisy dash).
    Why you should: Because if you have lowered your car, for the $45 in parts and minimal fitting cost, its cheap insurance you are not compromising your handling or letting the stock links decay faster (wouldn't want one of those breaking on you).
    Enjoy...
  3. #73
    Mar 2008
    Anstead, Brisbane
    thanks for the update noone. Just ordered myself a pair
    Am i right in assuming its a DIY job, just remove wheel and replace stock part?
    Daily - 2007 Polo Match
    Project - 1991 Mk2 GTI (Track Project)
  4. #74
    Jan 2009
    blankedy
    Quote Originally Posted by oliverconnell View Post
    I had my mechanic fit them, maybe one of our resident mechanics can comment here...
  5. #75
    Feb 2008
    Just looking at it, the way I would go about it is just leave the wheels on the ground, turn the wheel until the Drop link is exposed to work on, and then replace it. Why I would do it lik this is that the sway bar is in its normal position, making the parts easier to line up when fitting.
    If the car is raised, this means the suspention is slack, and will drop to its lowest point, meaning you are going to have to lift the suspention back up to have the components line up.
    Like I said, this is just how I would do it.
  6. #76
    I should get me some of these... HMMMM
  7. #77
    Feb 2008
    Quote Originally Posted by GoLfMan View Post
    I just did... Ahh, the joys of being in hospital with nothing more to do than surf the net and spend my hard earned!!
  8. #78
    Aug 2008
    Quote Originally Posted by Blitzen View Post
    Hope you didn't get injured in the line of duty.............
    Cheers,
    John
  9. #79
    Quote Originally Posted by JCM308 View Post
    yeh.... severe blisters on his preferred hand
  10. #80
    Feb 2008
    Hahahahaha...Nah, I have an evil little bug in me that thinks nothing I eat should be in my body, so it is doing a spring clean!!
