Heyo,
Long time since I've had time to sit down and post
Got my car registered early January, and have already started modding it back to what it used to be.
So the car I initially was working on and trying to get to stage 2, I'm done with. It's now my brothers and every time I need to do anything to it, he has to do it and learn. He said he wants to eventually get to Stage 2, but right now he doesn't care too much, it's fast enough for him.
My Car:
Gavin's old 3" exhaust is on (really needed it because the car didn't like the 2" to 1.5" thing I made for the roady)
Boost gauge back in
Rear sway bar is on
Husslas are back on it
PD160, pod in the stock airbox and upgraded the turbo inlet tube too
SAI delete
BOV upgrade, but not venting to atmosphere
Audi S3/TT Intercooler is being installed currently and here is my progress and dilemma
about the only solution I can think could work (using 2.5" not what I done, this was just an idea), need to trim the plastic shroud that goes into the radiator support. Will be finicky but oh well. open to other suggestions
Completed all the easy wiring relocation, stripped back the harness and re-taped it all with black electrical tape.
Redone my vacuum lines too, swapped out back to the 4 bar fuel pressure regulator
Need to still extend the pcv line to other side of manifold, so too the throttle body line and a U shape to fit onto the middle thingy
Need to still extend the MAP sensor cable. Need to get a mount for it too and fit that somewhere onto the passenger side before extending this cable.
Started on the plumbing. Sort of sorted out drivers side, passenger side is missing a few bits, only in front of the battery. Managed to sort out the first section from the intercooler.
Left To do:
Bilsteins when they arrive, paired with the k1 springs
Heated seat loom so the leather seats I put in can function
Find the TT mesh that fits over the bracket that sits under the manifold.
any comments/ideas would be appreciated
Thanks )
