Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Which fmic is best for polo gti??? Apr, forge or seat????
    Mar 2010
    Lynbrook, Victoria
    Smile Which fmic is best for polo gti??? Apr, forge or seat????
    hey guys, im looking to get a FMIC installed for my Polo Gti real soon, and just wanted some of you opinions as to which is best suited for the Polo.
    Im choosing between 3 front mounts which are most talked about, that is the Apr, Forge and Seat, however can not make up my mind...
    im interested in one that gives out the most gains and value for money. and where can it be purchased?
    also if your from VIC, can you direct me to someone who can do the job for a good price.
    Thanks guys
    Aug 2009
    I'd personally be going for the APR or the Forge myself.
    The SEAT is just too big IMO (and hence, will give you more lag)
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
    Jan 2009
    blankedy
    Good timing on your question.
    - The APR one is very expensive for what it is. It should flow very well, if you don't mind the extra spend and are thinking you may change the turbo down the track, this is worth considering.
    - The Seat one is designed for the diesel engine. I don't think its really bolt on, needs a fair amount of custom piping. Its also hunge and there have been some concerns raised over its restricting the radiator (and adding weight). Also not cheap by the time you get custom piping, likely modified crashbar, etc. I reckon you'd be up for most of 2K by the time you get it here and have someone fit and make all the custom connections.
    - Forge. The Forge unit is quite well priced, but costs a bit to get here. It CAN be had for under $1000, but if you just buy it direct through the website, its more likely to be about 1200-1300. I have been speaking to someone who chooses to remain anonymous, and apparently the Forge unit is causing restriction, robbing possible boost / power. This has been noted previously, but the measurements seem to vary...
    The Forge unit comes with all the clips, pipes, silicone hoses, brackets, etc. It even comes with a modified crash bar which would need to be altered to fit most coolers.
    I've got the forge unit, it was a great project IMO and the DIY guide was fantastic. The boost / power loss was not evident when I installed the unit, but the lack of heatsoak was. There are quite a few Forge Coolers going around.
    Option 4, is going somewhere who can get a quality cooler and do the custom piping for you. For this I think you need a recomendation and someone who does not charge the world.
    Before you do the cooler, I'd get it chipped, get the seat intake section / pod filter and maybe a dump pipe. The Front mount is not going to make as much of a difference in Winter as it does in summer.
    Aug 2009
    Another option to consider is buying a decent core and getting a reputable exhaust shop to do the fitting and piping for you. I've seen some excellent examples like this for around $1k including fitment.
    Jun 2009
    I would say the forge kit is probably the best bang for buck.
    However if you are planning on further mods, teh Seat one has been tested in South Africa and is more than capable of handling the further mods with very minimal heatsoak.
    It also showed no real loss of air flow to the radiator.
    So it really depends what furhter mods you want to do and if you want a cheap/good one or an expensive/excellent one.
    Mar 2010
    Lynbrook, Victoria
    thanks for advice the fellas. ive already got a BMC pod in. i was told getting it Chipped would be the last thing to do? because they run a dyno and tune your car, instead of having to tuned it each time. i think i might just go APR, the price tag on those things r hefty compared to others. but its godah be done.
    Nov 2008
    I have a Forge one and from the latest dyno day my car seems to be down on boost compared to another K04 Polo with a different intercooler. The upside was that the power was consistent across 3 runs. There are plenty of people with the stock turbo who feel that the Forge works fine. So I am going to sell mine, see http://www.vwwatercooled.org.au/f24/...tml#post495871
    Mar 2007
    Gold Coast
    Quote Originally Posted by robihe View Post
    You won't need a re-tune for a FMIC, intake or exhaust. Pretty much everyone here runs off the shelf maps. Once you start playing with bigger injectors and tubos etc. you might need to look at custom tuning, but I think most of the companies can supply maps for those too (without dyno tuning).
    Jan 2009
    blankedy
    Agree with Philthy, you don't really get the car tuned on a dyno with most tunes. The company develops a tune, its customized locally for Aus peramteters (temps, humidity, fuel quality, etc). Some companies customize the tune to the individual car more than others, I'll leave it at that...
    You've got a BMC? did you relocate the battery or get a smaller battery?
    Some have more adjustment by the tuner, but for a brand like APR tune, there are 2 options for the tune and don't have anything to do with the supporting mods.
    There are additional tunes available, but these are based around different turbo's.
    Some tunes have a 'Stage 2' which is based around intake, dump and intercooler, but the power difference is not massive. If you are considering going straight to one of these Stage 2 tunes, it will likely be cheaper to get the mods done first.
    Have a read of some of the chipping threads, lots of opinions in there.
    Mar 2010
    Lynbrook, Victoria
    i see. nah we didnt bother relocating or downsizing the battery, everything is pretty squished.
    so do youz recommend getting the car chipped then getting the fmic and full exhaust? or it doesnt realy matter which comes first.
    also i heard from someone today that when installing a FMIC there may be issues with some functions of the car, like the
    air con...is this true??
