I've tried lining the wheel well etc with carpet underlay and the difference was minimal. I notice extra noise even with just the rear shelf removed.
carpet unerlay is not a noise barrier.
Have a read on noise treatments, some absorb, some block. I used something like dynamat, but cheaper and a 6mm medium density closed cell foam, as a barrier. Made a big difference. Used it on the passenger side floor, in front of the doors, cover where the cables for the doors pass through, the hole behind the side mirror. I used the dynamat like stuff to add mass to large resonating panels and blocking cable access holes, etc.
Over all, made a huge difference, but I think to get a reasonable result, you've got to be willing to spend atleast a day and spend atleast $100 and well upwards to get it done well. I added about 6kg to my car, happy with the results, even the stock speakers in the doors sound better.
It works fine for some frequencies but obviously not the ones in cars (and I'm using the heavy duty industrial stuff, not the cheap, çrappy eggshell $hit that they supply for free with your carpet install).
I have a friend who builds speakers as a business and he uses the same carpet underlay (amongst other materials) to dampen internal reflections in his cabinets.
BTW If you use a subwoofer and and head unit/amp that allows bass redirection, you don't need to line your doors. Nobody can understand the sound quality in my car after I tell them that the drivers are stock but the bass has been removed from them.
- You may not post replies
- You may not edit your posts
Forum Rules
