Results 1 to 3 of 3
Thread: Fault Codes - This old chestnut...
    Sep 2011
    So, I've recently returned to the world of Polos and have picked up a GTI that needs a bit of TLC. I've cleared most of the fault codes, but the following remain.
    Physical symptoms are that the power steering doesn't want to work and the ESP light is on in the cluster as well as the ESP OFF button being illuminated.
    If anyone's willing to have a go at deciphering the below or has experienced and fixed these problems before, I'm all ears and would be incredibly grateful!
    Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
    Controller: 6Q0 907 379 AS
    Component: ESP 8.0 front H06 0003
    Coding: 0002550
    Shop #: WSC 31414
    VCID: 8E6FBAE5D94F
    4 Faults Found:
    00778 - Steering Angle Sensor (G85)
    005 - No or Incorrect Basic Setting / Adaptation
    01315 - Transmission Control Module
    004 - No Signal/Communication
    18055 - Check Coding of ECUs on Powertrain Data Bus
    P1647 - 000 -
    01314 - Engine Control Module
    000 - -------------------------------------------------------------------------------
    Address 08: Auto HVAC Labels: 6Q0-820-045.LBL
    Controller: 6Q0 820 045
    Component: Klimaanlage X0840
    VCID: EAA7D6758567
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    79-00 - Please Check Fault Codes-----------------------------------------------------------------------------
    Sep 2011
    Update - I've managed to clear this code:
    Used the Basic Settings guide on the Rosstech website to do this using VCDS:
    Steering Angle Sensor (G85) Calibration
    [Select]
    [03 - ABS Brakes]
    [Fault Codes - 02]
    [Done, Go Back]
    Start Engine (session still running).
    Turn steering wheel at least 30 ° left and back straight ahead.
    [Meas. Blocks - 08]
    Group 005 Field 1 (Steering Angle Sensor -G85-)
    Specification: 0.0 °
    Tolerance (when straight): ±5.0 °
    [Done, Go Back]
    [Security Access - 16]
    Enter 40168
    [Do It!]
    [Basic Settings - 04]
    Group 001
    [Go!]
    [Done, Go Back]
    [Fault Codes - 02]
    All fault codes should have disappeared.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Mornington Peninsula, VIC
    I was going to link the RossTech Wiki, some good stuff on there.
    What codes are remaining now? the "01315 - Transmission Control Module" ones?
    Can you post the full scan please.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
