Results 1 to 3 of 3
Thread: Fault codes - Faulty MAF???
    Feb 2010
    I'm receiving these fault codes and the car is going into limp mode:
    Address 01: Engine
    3 Faults Found:
    17963 - Charge Pressure: Maximum Limit Exceeded
    P1555 - 35-10 - - - Intermittent
    16487 - Mass Air Flow (MAF) (G70): Signal too High
    P0103 - 000259
    16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
    P0011 - 35-10 - - - Intermittent
    Readiness: 0000 0001
    Address 03: ABS Brakes
    1 Fault Found:
    18265 - Load Signal: Error Message from ECU
    P1857 - 000 - -
    Any ideas???
    2020 VW Golf R
    Clear the codes and see if they come back.
    Boost pressure exceedence and the cam fault are more of a big deal for me. Google them
    http://wiki.ross-tech.com/wiki/index...5/P0011/000017
    Aug 2007
    Over boost will be the one that makes it go into limp. Ive seen ME7 Audi have the load signal error , does your traction control light come on too?? If yes then that will be the MAF, load signal error in the brakes is the MAF. Still couple going on there. I would be checking the boost and N75. The p0011 code is for the cam adjuster, my A4 throws that one from time to time but doesnt limp, i do know my cam chain adjuster unit is flogged , cause it to bad start now and again. Not limp though.
    Jmac
    Alba European
