Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 112
Thread: Fastest polo in Aus
  1. #21
    Sep 2006
    Didnt VWindahouse change his driveshafts ? If so Anthony, any comments ?
    MODS- TOO MANY
  2. #22
    Dec 2006
    Quote Originally Posted by vwthunder View Post
    he did man but I know Kai's had to more then just the once.
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
  3. #23
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by jasn78 View Post
    Eddy has run his down the quarter before and while I know he could beat me he has always had problems on previous runs.
    I'm guessing he's traction limited
    the thing it defintley does help with is when running 25psi it gives me alot more contact patch
    I wonder if the taller sidewall and softer tyre pressure is also letting the tyre distort a bit and absorb some of the take off strain (like the wrinkle wall tyres that drag racers use) giving you a better launch.
    The semi-slicks wouldn't do this since they have really stiff sidewalls (which with the extra grip would also really load the drive shafts).
    Resident grumpy old fart
  4. #24
    Aug 2009
    13's is great!!!
    the soft sidewall is almost certainly helping in the tyre to bite (this has worked a treat with my torana to grip off the line)
    if you pumped up the rears rock hard it might even resist some of the weight transfer to keep more of the weight over the front.
    some other weight saving techniques are to remove all the insulation you can reach, seats etc and focus on the back half of the car, so more of the remaining weight is centered to the front.
    now reckon we can convince you to stick in a NOS kit and pipe in an extra 50 or so HP? a thin plate about 3/4 inch thick on the throttle body would do the trick with two drilled nozzles for the NOS jet.
    06 Polo GTI
    standard ECU, wheels | K&N Panel filter | PD160 intake tube and trumpet |Nulon 5W-30 | Michelin contact sport 3
  5. #25
    Dec 2006
    Quote Originally Posted by blackbetty View Post
    13's is great!!!
    thanks man, MMMMM NOS don't give me ideas lmao
    ---------- Post added at 12:49 PM ---------- Previous post was at 12:45 PM ----------
    also on the topic of stiffening the rear for weight transfer i was thinking get some sort of chocks made up to put in the rear springs. Any suggestions where I could go for this?
  6. #26
    Feb 2007
    Not bad, could keep up with my dunnydore :p lol.
    Keen to know how much power it has.
    Is there a greater time you are chasing?
    MK1 GLS 3door
    A4 B7 2.0T
  7. #27
    Dec 2006
    Quote Originally Posted by Spyda View Post
    Spyda, the joys of RWD vs FWD as for times to be honest cracking a 13 was that big for me I dont know now, but I do have rear seats to get rid of and a few other basic weight loss ideas so a 13.7 would be within range I think.
    And remember boys and girls if you say thats not possible and I do it you will get quoted lol
  8. #28
    Nov 2007
    Quote Originally Posted by Gambit View Post
    6r polo gti should beat it easily with fewer mods ?
    Actually no .... 6R GTI does not have launch control and even tuned is significantly slower in a straight line than a tuned 9N3 ....
  9. #29
    Haha teasing boys , but I do believe a 6r gti will hand you an ass whipping on a silver platter ala apr gti
  10. #30
    Feb 2008
    Hahaha, until the DSG blows up or the 1.4TSI starts eating its piston rings!!
