Hoyhoy.
Yep common, try operating the window up & down several times, but when doing so hold the button after each movement for a couple of seconds, then switch the key off for 30 seconds.
If it doesn't fix it the first time try again.
Hi guys,
After removal of battery terminals and as per topic 'Fast Glass drivers side not working or working only occasionly!'
Is there any common or reasonable explanation for this behaviour?
Cheers Al
Hoyhoy.
Hooroo.
Eddy, pleased your onto this matter with aquick response to a aften underated problem............
Thanks for help.......... cheers Al
Thanks Eddy, wondered about a solution to this slow glass fast glass problem......... will do.
Cheers Al
