Most likely an issue with a wheel speed sender. Quite often it's a rock or bit of metal in there.
Hi,
Just started happening today after put something in the boot (baby capsule) and drove off. Abs seems to kick in very early now. Bit nervous driving Around! Any idea what it means?
Huh, turned out to be a partially broken fusible link... Leading to under voltage at the abs units Bizarre.
And front brake pads were shot
Weird because it wasn't a complete break. Oh well, better than having to replace the abs unit
