Matty/FlyingGTI can make up the CAMS safety "stickers" in straight vinyl so that if you're careful, you can peel them off between track days and reuse them. Obviously, you will need to really clean the paint surface before putting them on so that they adhere properly but you could also put some clear tape around the edges to make sure they don't fly off.
I'm gauging interest so he can run off a decent number of sets so cost should be similar to the normal stickers. No one seems to be interested in the Motorsports sectionso I've reposted here.
Is anyone else interested in a couple of sets besides me?
Resident grumpy old fart
Details and price there kaanage?
