Originally Posted by
Martin
They have an adjustable ball joint, you can get over 1 degree of negative camber which
How does this work? Are the ball joint holes slotted rather than circular holes so that the ball joint can be shifted in or out? Could be good to go along with the camber plates. Any idea of likely pricing...?
http://www.superpro.com.au/supaloy-v...m/download/141
Resident grumpy old fart
