Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: EOI Superpro Supaloy control arms for Polo
    Sep 2010
    Wheelers Hill
    Re: EOI Superpro Supaloy control arms for Polo
    Hopefully there the same as mk4 would love a set
    Sent from my GT-I9100T using Tapatalk 2
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Martin View Post
    They have an adjustable ball joint, you can get over 1 degree of negative camber which
    How does this work? Are the ball joint holes slotted rather than circular holes so that the ball joint can be shifted in or out? Could be good to go along with the camber plates. Any idea of likely pricing...?
    http://www.superpro.com.au/supaloy-v...m/download/141
    Resident grumpy old fart
    Sep 2006
    I guessing they will be around the same price as the Golf ones or a bit cheaper
    A bit expensive just to gain 1 degree camber
    MODS- TOO MANY
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by kaanage View Post
    Yes, you can often get up to 1.5 degrees of camber
    Not sure if it's wise to go much further (with camber plates as well)
    Sep 2006
    I have 3 degrees with camber plates, dont need any more !!!
    In saying that, if they were cheap enough i would buy them, seeing as the setup is different to a MKV it should be quite a bit cheaper
    MODS- TOO MANY
    Jan 2009
    blankedy
    Any vague idea on how much these will be? 100 or 500?
    Feb 2007
    Brisvegas
    Sorry guys I really don't have any details yet. I would expect them to be cheaper than the later model Golf ones.
    Jan 2009
    blankedy
    I was thinking they'd be more as there is a smaller market for them, but I expect that depends on the production / engineering methods.
