Gone to a good home - somebody scored well.
Sharkie, Neil's car had a dyno after each mod so he has all the data to back it up, same dyno each time -so its great results.
From what I gather, the piping size & intercooler end tank design seems to effect power output somewhat and the unknown pressure drop & efficiency seems to really throw the figures out.
What you should do is flow test your intercooler (and Jason's too) first off the car - compare the results & then do some back to back intake temp reading & timing pull readings an multiple pulls on the dyno. We know on our car that we pull zero timing after 6 consecutive pulls, and still run run intake temps within 15 - 25 degrees of ambient.
