Results 1 to 2 of 2
Thread: Engine light problem
    Jul 2015
    VIC
    Hey all,
    I'm sure this may have been covered before I can't seem to find it, but I keep getting my engine light popping up due to the fact that my secondary air induction (if that's what it is called) has been removed and the egr blocked. Is there a way to stop the engine light coming up or would I be needing to go custom ecu or actually buying the software itself so I can just clear the code?
    Thanks in advance
    Aldo
    Sent from my SM-N9005 using Tapatalk
    Quote Originally Posted by PULS8T View Post
    Hey all,
    Thanks in advance
    Aldo
    It's not EGR exactly but it is to do with emissions.
    You can clear the code until the cows come home but the fault will come back every time with no pump fitted.
    I have tunes that will stop the light coming on, although the ECU still sees the inadequate flow. I can do them for Phase1 and Phase 2. The same cost, so I reckon it's worth fitting a downpipe at the same time.
