Results 1 to 10 of 16
Thread: Eibach spring
    Jun 2008
    Eibach spring
    My mate said he can get me a set of Eibach low down spring for under 500, is this a good deal? Installation not included.
    Feb 2007
    Brisvegas
    For Eibachs not a bad price! But H&Rs' are about $200 cheaper and give a better looking ride height being about 10 - 15mm lower. Please hit the link in my signature to see the ride height of the H&R's.
    Nov 2009
    Is there a QLD distributor for the H&R gear?
    Sep 2006
    Quote Originally Posted by VWindahouse View Post
    But H&Rs' are about $200 cheaper .
    You can get H&R's for $300
    Jan 2009
    blankedy
    I've had the H&R's for about 8000 kms.
    They definitely make the car sit much nicer, less wheel arch.
    Handling is improved (less roll, etc) but with the stock shocks you get a bouncy effect and the ride can be a bit harsh.
    its good for the money, but if you are after good handling and can afford the more expensive options ($800-$3000 plus fitting) you will get Much better results.
    Springs are the cheap part, its the shocks that cost in the equation.
    I'm getting AP Coilovers which is supposedly made in the same factory as Wietch and KW. I've had bad luck with 1 shock being damaged in transit, but in a fortnight should have a review for you. They've cost me $850 inc post from UK, FYI.
    Quote Originally Posted by vwthunder View Post
    i asked a place today.$2000 for H&R springs,shocks ,bushs,swaybars(back/front/bottom/top) and install. not sure if thats any good was the first place i asked $1750 for same package but diff springs.
    what u guys think ?
    Dec 2008
    thats alot...
    I know i got my Eibach springs from america for ~350-400 shipped, and that was when the $ was 80c. now being in the 90's the value is much better.
    and you will want a set of shocks to go with your new spings, a very common setup is eibach springs and koni FSD's, for about 700US, or ~2k if getting them locally. depeindg on what you want, a set of coils from the US are mighty attractive right now.
    install should be ~250-400 depending.
    Mar 2009
    Southside, South Australia
    To give you some kind of idea on cost - Eibach Springs + Bilstein B8 + Top Mounts + Install cost me around $1500. I purchase springs from Eibach Direct for $320 and Shocks for a bit under $800 landed in 2 weeks from the US
    I was quoted around $1500 locally for springs + shocks with a 6 week lead time.
    I'm extremely happy with the setup, stiff enough to have some serious fun in the twisties, but not so stiff you skip around when you hit a bump. Achieved about 15 to 20mm drop. H&R Springs I think are rated at up to 40mm drop, whereas the Pro-Kit is rated at up to 30mm drop. I think Eibach do a kit that will go lower as well, but IMHO if your main goal is lowering and you dont care so much for comfort then go some cheap coilovers.
    Jul 2007
    Auckland, NZ
    Where did you get the Shocks from US? Which shop? would you care to share? i am interested in blistein B8.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Sep 2006
    Quote Originally Posted by insanekiwi View Post
    Yeah me too
    I didnt know you could get Polo parts from the US
