20mm ain't much!
I remember in early 2006 I enquired with Eibach for a price on their coilover kit. $5000+ haha
Hey Guys,
Got my Pro Kit installed last Friday, sad to say Im not really happy about the aesthetic changes....
Handling-wise, it firmed up the roll on corners nicely with no negative effects on ride.
But...It almost seems like there is no change in ride height when a 20mm drop is specified. Im not too sure about how "settling" suspension works, but I was wondering if someone with stock suspension on their GTI could measure the gap between the tyre and wheel arch for me on front + back??
I know I shouldve done this before I got the springs, just ran out of time.
I will measure mine when I get home and post em also.
Thanks ppl.
T Go
MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
20mm ain't much!
The Kit is a 40mm drop on a Polo and 20mm on a GTI if I remember correctly on the product specifications sheet on the Eibach site....
T Go
That's interesting then. There should have been some noticable drop. Also remember that the spring will need to seat in properly yet which will drop the car further. Hopefully after a few weeks you will get the drop you were after.
Another silly question, are you sure it wasn't a 40mm drop on the rear and a 20mm drop on the front for a standard Polo?
i can understand if you cant see much of a drop, 2cm aint that much. though if anything atleast it helps your handling.
T Go
its been concluded on this forum before that the eibach springs are a very subtle lowering. it still looks like a stockish ride height.
if you wanted low you should have gone with the H&R springs. there's plenty of pics on here showing both ride heights.
Thanks for that!
I just measured mine.... disappointing.
They are within millimetres of your measurements....
that really sux.
I didnt go H&R coz I didnt have the money to get shocks as well, so I just went Eibach, knowing it wouldnt be a huge drop... but was at least expecting an ACTUAL drop.....
dammit.
T Go
