Hoyhoy.
Removing the dome took a little bit of care & a angle grinder, plus some rags around to protect things.
I'm curious as to what ya going to do when the dome is cut down, you can't adjust camber with that alone with out something like these.
Sounds like you need the camber bolt kit to may be even the camber.
