Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 60
Thread: Eddy's Sub-frame hanger bolt cam sleeves
    Oct 2009
    syd
    Can you install these from the bottom of the subframe after removing the bolt or does the subframe have to come off?
    Sep 2006
    Tweed Heads
    Quote Originally Posted by Hilal View Post
    Hoyhoy.
    Easy change over with out taking anything out except for the old bolts, but there is but & that is if the hangers are damaged you'll have to lower the sub frame to put a reamer through.
    Hooroo.
    Anyone else interested in organising another batch of these to be made?
    Sep 2006
    Quote Originally Posted by Altec View Post
    There was just a batch made, you might have to wait a while
    MODS- TOO MANY
    Sep 2006
    Tweed Heads
    Quote Originally Posted by vwthunder View Post
    Hoyhoy.
    Troy, Craig (Altec) has asked me about getting a kit & I said to either add to your thread or to start another one, sorry.
    We are in the process to find out if he does have sub frame movement or may be he has bush problems.
    If he does have definite sub frame movement, I'll look after him.
    Hooroo.
    nsw
    Eddy,
    With standard struts & springs is it possible to eek out a bit of extra neg. camber and/or castor using the sleeves or is it more that everything will remain within factory limits just solid as a rock? Is there much need for things like front LCA cross braces when you have the sleeves in place given that the subframes will become completely static?
    Sep 2006
    Tweed Heads
    Quote Originally Posted by sambb View Post
    Eddy,
    Hoyhoy.
    You won't get any more of anything than with in factory limits.
    The second part of your question is for the experts to answer.
    Hooroo.
    Nov 2012
    Eddy how hard was it to remove the domed centre caps in the strut tops? I've got some MCA dampers coming soon, it'd be nice to be able to even out the camber there, rather than shifting the cross member around.
    I wouldn't mind a set of your sleeves, if there is another buy, BUT I truly believe your kit needs to be industrialised and produced in quantity. If you want to talk about that let me know.
    Oct 2010
    Melbourne, VIC
    3D print them?
    Resident grumpy old fart
