Mate...You're opeing a can of worms. Chip wars have resulted in much bad feeling on other forums and I wouldn't like to see that happening here.
I have no problem with the publishing of factual information from chip manufacturers as long as the playing field is level. In other words the cars in which chips/flashes are installed must be stock standard in all respects so that no other variables are introduced. This could even be extended to using the same dyno (because the do vary, you know ).
"My Dad's Bigger than you Dad..." arguments have no place here. I'd suggest that you go to the manufacturers' web sites and research there.
