If you upgrade the rears in the same way you upgrade the fronts (Eg. TT size front and rear), it won't upset the biasing will it?
There are a couple of guys over at UK-polos.net that have swapped to 256mm rears using all OEM parts and they like the results.
So to my original question, will they fit???
Also excellent read with bias comparrisons from ECS
http://www.ecstuning.com/stage/edpd/...l=&engine=1.8T
And yes I will be tracking the car at least once a month and going for the ECS stage 3 front brembo upgrade as well!
Thanks
ill certainly be upgradeing to slotted rotors after seeing what happened to plautos's rotors after tracking his beast. though i guess theyd get quite punished on the track.
- You may not post replies
- You may not edit your posts
Forum Rules
