Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: ECS Porsche caliper???
    Sep 2008
    Hey guys, been looking at upgrading the polo's brakes for quite some time and came across these from ECS for the 1.8T Mk4 golf. Anyone know if these should fit or not? I've also got VW Exor STP 17" wheels.
    Volkswagen Golf IV 1.8T > Braking > ECS Stage 2 > ES#1168 ECS Stage 2 Big Brake Kit - (Silver Porsche Boxster Caliper, 12.3 One Piece Rotor) - MK4S2BBK-SSLT
    Thanks for your input guys.
    Sep 2006
    I cant see why not
    TT kits 12.3 fit so I am 99% sure it will, and laura just put the same kit on her car she bought second hand
    I have a the porsche kit, but is suited to a S4, just had to space the carriers a little
    Sep 2008
    Thanks mate for your input. Sometimes it's kinda frustrating and off putting when you're unsure if things would fit or not cause there aren't a great deal of parts listed specifically for the polo like there is with other VAG models. If only our pog was sold in the US, then they'll be heaps more parts for it.
    What size wheels are you running currently? 16" or 17"s?
    Cheers.
    Sep 2006
    Well dont have them on yet
    I have puled them on and off many times to check fitment, get the right carrier spacer made up
    They will go on when i have money for tyres lol
    I know you can run them with some 16's, but because the calipers are quite wide they will only fit with certain wheels
    Sep 2006
    Standard wheels would need to be spaced out about 20mm
    Sep 2008
    So I guess with 17" VAG wheels, I should fine with regards to clearance then cause I don't really want to go putting on spacers due to the possible insurance issues etc.
    Would be nice to see them up and running on both our cars then.
    Cheers mate.
    Jan 2009
    blankedy
    I think you will need something with a low offset and spokes that don't sit in too far.
    Sep 2008
    Does anyone know what/if offset for the exor stp 17" VAG wheels are? I can't recall if its et35 but its definately 17 x 7 from memory. Sorry guys, will need guidance about this whole brake upgrade and wheelfitment thing as I'm a complete noob and clueless when it comes to brake fitment (apart from changing pads and flushing brake fluid) and the associated wheel offset etc.
    Cheers.
    May 2010
    Perth
    I have been looking at the same upgrade for my bora 4mo.
    You will need to be very careful with the spoke clearance as this is the major issue.
    There is a wheel fitment guide here:
    http://www.ecstuning.com/stage/edoc/...III-Stg2v1.pdf
    print and cut it out, put inside rim and see what your clearance is like.
    you may have better luck with the 2v2 kit as they use a custom rotor to give more clearance, but then may have issues with the 330mm rotor clearing 17's. you are then also limited to replacement rotors from ECS rather than off the shelf rotors, and pads need sligh modification to fit.
    They are also back ordered with no ETA on stock coming in. I've been waiting a month or so.
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    Jun 2009
    The offset should be stamped on the back of the wheels Dave.
    If you can't find it out here than you can always check on the back.
